RCP Wall Thickness and Weight by Class
I need help. I can't find a table that shows the pipe wall thicknesses for different classes of pipe. In addition, I can't find the difference in pipe weight by class. Anyone out there have this information or know where I can get it?
Thanks in advance!
Thanks in advance!
RE: RCP Wall Thickness and Weight by Class
ASTM C76, Standard Specification for Reinforced Concrete Culvert, Storm Drain, and Sewer Pipe
weight is not specified, you would need to get that from the manufacturer or estimate it yourself
CVG, I don't have that standard in house. But I did find a metric version and it looks like the wall thicknesses are the same for all classes of pipe. I would like to see how much the weight is increasing since I imagine the difference in strength must come from the reinforcement. Would you be able to point me to a place I can look at the ASTM standard online? Or send me a PDF of it? Thanks!
the wall thickness does remain the same, the concrete strength and amount of steel changes
try this
http://www.concreteindustries.com/images/product_s...
http://www.rinkerpipe.com/TechnicalInformation/dra...
