Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I think the site is just incredible....I am learning more here than anywhere else before and am looking forward to being able to help someone .... this is my idea of what the Internet is supposed to do..."
Geography
CATIA v5 r19: HOW TO TAKE MEASUREMENTS IN SECTION VIEWS
Matharu519 (Automotive)
30 Jul 12 14:11
Hello all,
This is my first post on this site...hopefully not a dumb question. How do I take measurements at different plane sections through an assembly? I am able to view sections but not able to pick off measurements at the sections. I was thinking to intersect the partbody with a plane and then pick off measurements from the intersection as a work around?
Thanks in advance
jackk (Mechanical)
2 Aug 12 12:43
I just checked and you can take measures while sectioning in both the assembly window and the section window. (at least with R18)
Make sure you have the Tools + Option activated to ALLOW MEASURES ON A SECTION WITH A SIMPLE PLANE
2 Aug 12 13:10
Tools + option? I'm not sure what you are referring to. Where in the menu/toolbars do I find this?
jackk (Mechanical)
3 Aug 12 9:14
On the top menu of the CATIA screen, click the TOOLS menu, and then click the OPTIONS sub-menu. This will bring up the OPTIONS window where you can define how you want CATIA to behave.
In the OPTIONS window; on the left side is a "tree" of sections (kinda like a list of workbenches). Click the MECHANICAL DESIGN section on the left, and then click the ASSEMBLY DESIGN sub-section.
Across the top of the OPTIONS window are a series of tabs / pages. Click the DMU SECTIONING tab to see the list of options.
The top portion of this page has about 8 options for the SECTION PLANE. Activate the last option to ALLOW MEASURES ON A SECTION CREATED WITH A SIMPLE PLANE. (the box in front of the option will be orange when it is active)
Click OK at the bottom when finished setting the Options for your CATIA session.
These options are saved with your userid, and will stay in effect until you change them. So, you don't have to set them everytime you start CATIA.
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
