What is this type of spring called?
So I am trying to design a spring mechanism like this and would like to see if I could find a supplier in order to get them cheaper than being custom made. However, I have no earthly idea what these things are called. I would've guessed 'hinged leaf spring' or 'buckle spring' but Google doesn't seem to concur.
Thanks!
Thanks!
RE: What is this type of spring called?
Spring Closures
Sewn into the mouth of a pouch, the spring closure snaps flat to close the bag. The closure is often made of two parallel plastic strips that are held together by expandable hinges. These corners can be pushed together to expand the bag's opening, and the bag shuts by pushing the two parallel bars together. The closure is placed in between the outer fabric and the bag's lining, hidden from view. This style of closure can work well with bags that are designed to lie flat, including clutches and hobos.
Ted
