Convert model co-ordiantes to drawing sheet co-ordinates using NXOpen ?
Hello Everyone,
How can i convert model co-ordinate values to drawing sheet co-ordinate values using NXOpen ?
A Sample prog will be of good help.
Amitabh
Amitabh
RE: Convert model co-ordiantes to drawing sheet co-ordinates using NXOpen ?
ufs.View.MapModelToDrawing(dwgview.Tag, originpnt, pnt1)
The user fuction entry should explain all
int UF_VIEW_map_model_to_drawing
tag_t member_view,
double model_pt [ 3 ] ,
double map_pt [ 2 ]
tag_t member_view Input A Member View on drawing
double model_pt [ 3 ] Input Point in absolute space
double map_pt [ 2 ] Output 2-D point on the drawing
Frank Swinkels
I finally figured it out on my own by doing some research at my end and i have used a similar wrapper and it is working as expected.
Thank You.
