Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This has been the MOST helpful forum that I have been a part of and I want to say thank you. The tips, tricks and helpful advice that you all contribute to have been lifesavers in many instances..."
Geography
CroninD (Mechanical)
30 Jul 12 6:36
Hi guys,
Relatively new to GD&T. I have a base plate in an assembly with two counterbored slots in it. I know how to geometrically tolerance a normal UN-counterbored slot; i.e;
Link
How do I go about it if the slot is counterbored from the underside to give clearance for a socket head cap screw? Is it the same as dimensioning a counterbored hole minus the diameter symbol? Or should i tolerance the top and counterbored sides seperately?
Any help is much appreciated.
D.
KENAT (Mechanical)
30 Jul 12 15:39
I'd probably tolerance/dimension as two 'coincident' slots where one of them has a depth associated. I'd probably dimension the depth in a section view just to make clear.
If using position & envelope principle to locate the slots I think this should work OK and minimize chance of confusion.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
CheckerRon (Mechanical)
30 Jul 12 15:42
I've done this before and there is a couple ways. You can dimension the slot and the counterbore slot to the same datums each having it's own FCF and maybe a relaxed tolerance on the counterbore, or you can positional tolerance the slot a per the standard and give it a datum, say D. then tolerance the counterbore slots to datum D, "4X INDIVIDUALLY" (or however many there are).
Close Box
Join Eng-Tips® Today!
Join Us             Close
