Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I wish I knew about this site years ago. It would have saved me a lot of heartaches..."
Geography
susanbhj (Mechanical)
30 Jul 12 3:16
Dear friends,
While designing nozzle for "design for MAWP or MAP", I noticed that while checking for MAWP case for nozzles, compress is adding Liquid static head on flange.
Guys, do you think it is necessary to add liquid static head? In my opinion it is not required.
What do you think, guys? Share your opinion.
Susan
vesselfab (Mechanical)
30 Jul 12 7:48
the pressure, whether map or mawp is at the top of vessel. the code requires that you design for all known loads. static head is a load on nozzles, especially those low in a liquid vessel.
NTME76249 (Mechanical)
4 Oct 12 14:39
We add a static liquid load to all vessels just to be safe, it can really make a difference on large OD Vessels. I would recommend it.
Michael McMillan
http://cadtechie.blogspot.com/
AK23Static (Mechanical)
21 Oct 12 3:35
Software approach is correct, consider the situation of Column design where liquid head can make quite a big difference for the nozzle located in the bottom section.
cheers
AK
Beginning of every success is desire
vesselkid (Mechanical)
15 Nov 12 13:08
susanbhj, MAWP for a vessel is measured at the top of the vessel (i.e. without hydro-static head); however, for each competent, MAWP shall be computed based on min. thickness and corroded diameter; Hydrostatic head at a point in a vessel must be added to the pressure used (normally vessel MAWP) when calculating the required thickness of the vessel component at that elevation; however, You must subtract hydrostatic head pressure when determining the MAWP of a vessel. If given a vessel of multiple parts and the MAWP for each of the parts, the MAWP of the entire vessel is determined by subtracting the hydrostatic head pressure at the bottom of each part to find the part which limits the MAWP of the vessel.
Close Box
Join Eng-Tips® Today!
Join Us             Close
