NDT UT TEST FAILED
NDT UT TEST FAILED
hi guys,
I would like to ask what normally causes a UT test failure?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: NDT UT TEST FAILED
Common indications are slag inclusions within the weld, root problems (lack of fusion, root undercut, cracking, etc.), weld fusion along the prepared face, interpass cracks, interpass fusion, etc.
What did the UT report reveal?
It might help if you explain to us how or in what respect the test failed. There must be more to the story than simply...the test failed.
BA
Check to see that the person doing the testing is appropriately qualified, wherever you are located and by whatever organization is noted in your codes.
Air/Arc gouging is a common method of removing anomalous conditions before re-welding. Grinding is another common method.
Check also to make sure that your company is following its approved welding procedure (assuming you have such).
www.FerrellEngineering.com
