Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I am very happy with the whole site and would like to extend my compliments to all of you who work to make it one of the most useful sites (If not THE Most Useful) ...and the easiest to navigate..."
Geography
PackardV8 (Automotive)
29 Jul 12 14:35
From a couple of automotive replacement spring websites,
Quote:
Grease has an adverse reaction to spring steel which causes the steel to degrade and weaken the spring, so we do not recommend using grease/graphite between the leaves.
If this is in fact true, can anyone explain the chemistry?
jack vines
MiketheEngineer (Structural)
29 Jul 12 17:51
Nope - must be from the spring mfg - they want them to wear out!!
swall (Materials)
29 Jul 12 18:16
Utter nonsense. Just look at valve springs--running in oil, a lubricated environment. Valve spring failures (fatigue) I have seen are due to nicks, pre-existing seams in the wire and overstress due to improper installation or operating parameters.
GregLocock (Automotive)
29 Jul 12 19:47
The only explanation I can think of would be that the grease and dust and grit forms grinding paste.
I'll ask in the workshop, we've been building leaf spring cars for 50 years or more, someone will know.
Cheers
Greg Locock
30 Jul 12 13:50
Thanks for the replies. I don't get it either, but Eaton, a major supplier of springs has on their FAQ: Link
Quote:
Prior to the mid fifties grease was put between the spring leaves, in fact springs of many pre-50 cars were wrapped in metal liners to hold the grease in. Some cars had hollow center bolts with a grease fitting so the springs could be lubed on the car. The idea behind lubing between the leaves was to reduce inter-leaf friction.
Then in the early 50's the type of steel used to manufacture springs was changed to SAE5160 and the practice of lubricating between the leaves stopped.
Grease has an adverse effect on 5160 steel. The chemicals in the grease react with the steel and causes the steel to breakdown.
Take a look at the front springs on the next large truck you see leaning. There's a good chance the power steering unit will be leaking onto the low side spring.
Eaton makes a lot of springs for OEMs and the aftermarket, but is it likely a large truck/heavy equipment OEM would put a SAE5160 spring on equipment where lubricant leaks are a fact of life, knowing it would result in deterioration?
jack vines
MintJulep (Mechanical)
30 Jul 12 17:34
5160 is steel. There isn't anything particularly exotic about it. It has the things that most other steels have in it. There is rather a lot of chromium, but not enough to classify it as stainless.
Grease is applied routinely to all sorts of things made out of steel. In much more demanding environments than between leafs of a leaf spring stack.
Grease is routinely smeared on steel things that shouldn't rust in storage or shipping.
So I'm inclined to call BS.
rmw (Mechanical)
30 Jul 12 21:59
Even if the grease had some chemical or soap in it that reacted with or etched the surface of the steel, I can't imagine it having any worse adverse effects than road salt, MgCl, etc. And it would be a surface effect and I can't imaging it penetrating into the spring and degrading it.
And grease and ATF are similar in that they are lubricants, but other than that, quite different; different additives to petroleum products so that annecdote sounds like hokum.
So unless this is a case of SCC due to chlorides, I'm with the BS call.
rmw
patprimmer (Publican)
30 Jul 12 22:41
I'm pretty well of the opinion that greases are mostly formulated to protect as well as lubricate steel. While it might hold onto abrasive particles that find there way in there, it also helps keep them out in the first place and reduces the harm they do while there.
I call BS.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
pontiacjack (Electrical)
31 Jul 12 1:53
Merely "thinking out loud"...
Does this question possibly arise from the reduced internal frictional damping of a greased leafpack? To illustrate my ignorance, does a standing wave ever occur in a leaf spring if excited in some particular manner? Even if the center (or whatever point) is well damped by a separate damper ("shock absorber")? I just don't know...
31 Jul 12 4:31
The friction between leaves makes the ride a bit harder but reduces rebound control so the leaf spring loses some of its inherent self dampening effect.
Pat
for site rules
Tmoose (Mechanical)
31 Jul 12 8:05
Here in Massachusetts all the (less than a dozen, probably) busted springs I've seen ( and essentially all the unbroken ones, too) are quite rusty, but worn significantly where the ends of the leaves (leafs) rub.
page 83 here makes it pretty clear how badly rusted steel is impaired.
http://www.timken.com/en-us/Knowledge/engineers/ha...
swall (Materials)
31 Jul 12 8:33
Thanks for the Timken handbook, Tmoose. I have the paper version, but it was a little out of date (1983).
140Airpower (Automotive)
1 Aug 12 11:48
First of all, plain petroleum lubricants will not attack steels. I think that the only problem would have to come from an additive that is corrosive. I think that a lube maker would be crazy to put a corrosive or caustic additive in his product. Three very common additives are Lithium, Molybdenum Disulfide and Graphite. These should not hurt steels.
MikeHalloran (Mechanical)
1 Aug 12 14:33
Now, add salty water and re-evaluate those lubricants.
Mike Halloran
Pembroke Pines, FL, USA
Helpful Member!  140Airpower (Automotive)
1 Aug 12 17:21
Mike, adding salt water to greases generally results in very poor penetration to the metal surface. In other words, greases and oils tend to repel water. This is fairly well known. Conversely, adding salt water to bare metals has an accelerated corrosive effect. This is also fairly well known.
1 Aug 12 19:12
I think from some vague memories that greases are typically soaps or metal salts of large molecule organic acids that are mixed into a paste with fine clays.
I guess if a metal was used it could dissociate and form a galvanic cell with the iron or more likely some other component of the steel alloy, however the reactive metal would be the sacrificial one and this (having the metal in the grease being the sacrificial one) would certainly seem to be an objective when formulating grease. Anyway, from my experience, grease protects rather than corrodes metals.
Pat
for site rules
1 Aug 12 21:45
Pat, Petroleum greases are heavy hydrocarbons mixed with soaps.
The additives I mentioned are non-reactive with steels, as they would have to be in order not to corrode the metal surfaces. In other words, they would be no good if they reacted with the metal and would be anathema as a lubricant additive.
drwebb (Automotive)
3 Aug 12 13:22
Despite the source, the careless wording of the recommendation suggests it may be single tech service engineer repeating 'conventional wisdom'. After all, there are a host of different grease chemistries- some even non-petroelum- and if ALL were deleterious to 5160 steel it would be far too fragile to use in the application. Furthermore, power steering units normally are filled with hydraulic oil, so if that (as the FAQ claims) is also harmful why isn't exposure to petroleum in general (including engine oil and tar from the road) recommended against? It sounds a little apocryphal.
1gibson (Mechanical)
3 Aug 12 14:44
Claiming grease has an "adverse chemical reaction," why then also suggest to avoid using graphite in the same sentence? Does graphite have an "adverse chemical reaction" as well? Power steering fluid too? Any lubricant, solid or liquid, ever?
There must be a mostly mechanical answer. Lubricants decrease the friction, maybe the spring operates at a lower temperature and fatigue characteristics are worse. Maybe it is more prone to "sag" when it sits at rest because interleaf friction is much lower. I'd buy that actually.
"It just doesn't work and we don't know why" can be explained by black magic, or 99% of the population will also accept "an adverse chemical reaction" because they don't know the difference between the two.
A lot of people know that a lot of things "just don't work" and for most, "that's how everyone does it" is a good enough explanation. For engineers it is not.
But everyone knows mechanical engineers hate chemistry, so points for effort on this one.
Compositepro (Chemical)
3 Aug 12 15:05
Graphite and iron do experience strong galvanic corrosion in the presence of salt water. A mitigating factor is that it is difficult to maintain electrical contact between iron and graphite particles as corrosion occurs.
4 Aug 12 13:26
Compositepro, iron already experiences strong corrosion in the presence of salt water, so what is the role of Graphite here? Also, we are talking about a steel that is a near stainless steel. Some chemical environments corrode stainless as easily as non-stainless steels. Does graphite cause stainless to corrode more readily than non-stainless or is it simply that it reduces the corrosion resistance of stainless to that of ordinary steel?
5 Aug 12 0:15
It's all a matter of details. A piece a graphite connected to apiece of iron so a current can flow from one to the other, will form a battery in salt water. The iron will be gone in hours with hydrogen bubbles at the carbon. Of course, steel is an alloy of carbon and iron.
mfgenggear (Aerospace)
6 Aug 12 11:21
I have been lurking reading these post. & I find the manufactures comments amusing.
the only way the grease could effect the 5160 steel if some contamination was to be found in the grease.
thus causing some type chemical reaction.
Example would be faulty manufacturing of the grease it self, but I really don't see that as a possibility.
Mfgenggear
6 Aug 12 15:21
mfgenggear, what I'm getting is that although plain grease shouldn't be a problem, grease with graphite -a very common type- might be damaging in regions where road salt is used and 5160 MAY be more susceptible than other steels. I had not heard this before, but that's not a surprise.
6 Aug 12 17:58
Thats funny, Remember when you could buy oil with graphite, I use to use that stuff in my car when I was a youngster.
I must have easily achieved 300000 miles, :>)
any way it's possible but I don't believe it would. :>)
Mfgenggear
swall (Materials)
7 Aug 12 7:34
That would be Arco graphite.
gearcutter (Industrial)
7 Aug 12 22:23
Greases that use extreme pressure additives do in fact attack steal. It's the chemical reaction with either the oxide layer or the steel surface itself that produces the required lubricating properties.
But for it to happen on the scale required to cause a part to prematurely fail is highly unlikely.
Ron Volmershausen
Brunkerville Engineering
Newcastle Australia
http://www.aussieweb.com.au/email.aspx?id=1194181
Maui (Materials)
8 Aug 12 10:21
It has nothing to do with the establishment of s galvanic cell. It is important when lubricating springs to be sure the shock absorbers are functioning well. The potential for spring breakage increases once the damping effect of dry leaf upon dry leaf friction is removed. With OEM shocks, lubed springs are great. With no shocks, lubed springs can result in trouble.
Maui
www.EngineeringMetallurgy.com
8 Aug 12 11:00
Quote (Maui)
Fair and correct. But this is a purely physical phenomenon.
The original claim is that "Grease has an adverse reaction to spring steel which causes the steel to degrade and weaken the spring" which appears to have no basis in chemistry.
Maui (Materials)
8 Aug 12 14:13
Mint, true. The original premise that
is, to the best of my knowledge, patently false. It appears that someone drew an incorrect correlation between SAE 5160 leaf spring failures and the observation that grease was being used to lubricate them. The additional suggestion to
should make the reader question why the power steering unit would be leaking in the first place. Likely because the truck has significant milage on it. This number of miles creates wear and tear on the shocks, which no longer work as effectively as they should. And for lubed springs, these worn shocks can create the issue.
It appears that the faulty cause and effect line of reasoning for these observations was never actually confirmed, which is why they persist, even if they're are wrong.
Maui
Helpful Member!  Tmoose (Mechanical)
8 Aug 12 19:03
It was noted back in the 60s that UFOs were often seen near powerlines. The patently untrue explanation back then was that they absorbed or otherwise enjoyed the electromagnetic energy. Now we know the correct explanation starts with the fact that birds choose to sit singly AND in groups on powerlines (for reasons all their own), and UFOs are simply drawn close by their irresistable LOVE for birds.
rmw (Mechanical)
8 Aug 12 20:54
Back when I owned 18 wheelers, I got to have the fun of changing more than a few broken springs, but it never happened to the ones around the engine compartment that always were wet with oil leaks of some type.
rmw
Maui (Materials)
8 Aug 12 23:55
9 Aug 12 1:03
The lean on the truck would not be due to lube as the lube does not soften the spring, it simply removes a damper. Taking a non gas pressurised damper of a car does not change ride hight. Ride quality sure, but not ride height.
Pat
for site rules
Tmoose (Mechanical)
9 Aug 12 12:22
Hi Maui,
You said "It appears that the faulty cause and effect line of reasoning for these observations .."
My UFO tale was intended to be another "example" of faulty cause and effect reasoning. I figured it would be less controversial than the many examples distributed as news every day.
Maui (Materials)
9 Aug 12 12:44
Tmoose, thanks for clarifying.
Maui
TomDOT (Materials)
13 Aug 12 9:08
On the truck example, one might also think "Hmmm, fluids tend to flow downhill. Maybe that's why the power steering fluid trended toward the lower side...."
Or aliens. [3eyes] Blame the aliens.
RossABQ (Mechanical)
14 Aug 12 18:44
I guess I'm screwed, according to Eaton. I just took my '52 Ford trucks rear springs off for cleaning, lubing, and new bushings. I soaked them in ATF after cleaning all the dirt and scale off. They are original '52 springs (10 leaves on a 1/2 ton, if you can believe that). They have a groove running longitudinally for the express purpose of lubrication.
But my front springs have been replaced with current production Eaton springs, and the left front is right under my leaky manual steering box. 90 wt gear lube passes thru the box like water, keeps the leaves soaking wet. No sag or lean yet, but the front shock is inadequate with no friction to help.
Here's what comes from failure to lubricate on schedule... my rear leaves
swall (Materials)
15 Aug 12 7:37
Fretting has worn indented areas into the mating pieces. Fatigue cracks can then start from the fretted areas. One way to mitigate fretting is to LUBRICATE the mating surfaces.
Helpful Member!  Autotecheng (Automotive)
6 Sep 12 22:58
I also call BS. I see a variety of recommendations from manufacturers and OEMs that would lead to the premature failure of their products as well.
I went to research coil spring failure today and found this article from the british Automobile Association
Coil Spring Failure Season
Their empirical evidence suggests that road salt induced corrosion is the source of spring steel failure, perhaps some materials engineers can confirm or invalidate that claim, but they state:
Hydrogen embrittlement
Electrolytic action between the salt solution, formed by road salting, and the iron in the spring generates free hydrogen atoms which enter the steel and can cause microscopic cracking. Cracks propagate and combine, ultimately leading to failure of the spring.
I would also note that most coil springs are coated, plated, or painted in some way to reduce or eliminate corrosion.
And if I am not mistaken greases are hydrophobic - meaning they would repel salty water from the road and keep it away from the springs.
Conversely if the springs grind against each other with some grit or dirt and grease it may have an abrasive effect like lapping compound.
I believe this recommendation is made with the goal of increasing spring sales but I welcome insights from materials engineers on this report from the AA. I think the question is of a materials nature, and not a mechanical one.
-ATE
dicer (Automotive)
26 Sep 12 14:55
Use cosmoline it has been used for years on all kinds of steels and other metals, any thick protectant like that won't allow dirt in.
Close Box
Join Eng-Tips® Today!
Join Us             Close
