Dimensioning Problem
Is there a way to stop Pro/E from zooming out in sketcher after you modify a dimension?  When I'm zoomed in on a dimension and I modify it, Pro/E zooms back out to a full view everytime.  Can this be stopped?
RE: Dimensioning Problem
Just select to DELAY MODIFY until after all dims's are changed.
Steve
http://www.3dlogix.com
You can put this line into your config. I got this on 2001 but it should work on all versions.
sketcher_refit_after_dim_modify
set the value to NO
