PreSlab Construction
Got asn old Days Inn from circa 1958 that is owned by another chain, and the roof framing details refer to a "preslab". Looks like a 2" deep fluted section of precast concrete used as a form for a 5" total slab thickness. The positive moment steel for the floor is in the Preslab, and the negative moment steel is in the CIP portion.
Anyone know where I can get any info on this? It looks like it ends up being a composite section... Just want to be sure...
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
RE: PreSlab Construction
Do your drawings show the reinforcement? You probably only need the As values and the f'c right?
Mike McCann
MMC Engineering
http://www.concreteconstruction.net/images/Precast...
http://www.humes.com.au/holcimcms/uploads/HUMES/Hu...
Mike McCann
MMC Engineering
