Solidworks Fillet issues
High guys I am trying to add a fillet and am having an issue getting the results I am looking for. The part is a flat part .750" thick and has a .785" dia through hole. I can add a fillet R.094" using the face fillet command, however, I am trying to add a partial R.094" to the top surface(for lack of better terms). I would like the radius to start .070" down from the surface. Essentially the R.094" fillet would be .070" down from the top surface and extend .031" from the edge of the through hole on the surface. I cant seem to figure it out so if anybody has some advice I would appreciate it. Version is 2009
Jim
Jim
RE: Solidworks Fillet issues
