switch for allowing command while continuing in a command
We just upgraded to 2012 AutoCAD.
Previously, I was able to start a move command and in the middle of the command, I could measure and immediately return to my move command where I left off. This worked with copy and all sorts of others.
Now everytime I try to start a command while currently in another command, the initial command gets cancelled.
Is there a switch that needs to be turned off or on to allow this?
Thank you for your time.
RE: switch for allowing command while continuing in a command
For example when in the move command type 'z to enter the zoom command..when zoom is done it returns to the move command in process.
