Copying Detail views from one print to another
I thought I had done this in the past and can't seem to figure out why I can't do it now. Can it be done? I know I can drag a view in the tree and drop it into another print but I want to keep the original view on that print as well. The reason for it is to do a more detailed view in larger scale of a certain area and I'm out of room on the other print. The other thing I wanted to ask is there a way to repopulate the view pallette after the views have been used up?
RE: Copying Detail views from one print to another
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems." -Scott Adams
Derived views cannot be copied, but they can be CUT & pasted (i.e. moved) without having to move the parent view..
There are 2 circular green arrows at the top of the view pallet - those will re populate the drawing views.
