H beam @ low temperature
Hi guys,
I would like to ask if an H beam structure EN10025 S355JR would be applicable for -20deg C or lower temperature area?
Thank you very much.
RE: H beam @ low temperature
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Thank you for your reply I would just like to clarify, does it means that this values from the impact test temperatures will define which temperature I can build or use a certain structure?
This link might be useful:-
http://steelmanager.eu/files/en10025.pdf
