Linked body doesn't update
thread561-282562: Wave linking doesnt update all the time NX 7.5...
I read the above thread about problems with updating linked bodies.
I have the same problem. Is there already a solution?
I have loaded the referenced part fully and turned off partial loading.
When I double click the linked body nx says it is updating the body but nothing happens. In the window that appears it says: status: out of date.
It is a pretty big model.
Regards, Michel
Regards, Michel
I use NX7.5
HP Z600 Intel Xeon E5520 2.27GHz Dual
9GB Memory
Windows 7, 64-bit
Groeten, Michel
www.kvi.nl A leading Dutch institute in atomic and subatomic physics
RE: Linked body doesn't update
Even restarting everything doesn't help. I just can't update it. But I don't get any error and everything works fine.
See attachement.
Michel
I use NX7.5.4.4
9GB Memory
Windows 7, 64-bit
Groeten, Michel
Have you in your Load Options, Use Partial Loading On or Off?
Also you can do a foced update:
->Tools->Update->Update for External Change
Hope this works.
Best regards,
Pascal,
NX5.04+TC2007 (GM Toolkit) / NX7.5 native
You can use Partial Loading, but turn on the "Load interpart data". NX will then only load the necessary feature data for the links.
Tomas
what is interesting is i just had to move the original body and these features updated. the other thing is i have assoc. measurements on these linked bodies and they report out old values, they will update when i do the move.
running the ' update for external change' does fix this but it takes 10 minutes compared with moving the original.
nx 7.5.3.3
Scott Copeland
Design Engineering Contractor
Persego Int'l
www.persego.com
