Corrosion Resistance of Ferritic Stainless Steels
I'm looking for a ferritic stainless steel for a magnetic application which has better corrosion resistance than 430FR. I ran a salt spray test per RTCA/DO-160D and surface corrosion appeared within 24 hours. This is not acceptable to our customer. Any information would be appreciated.
RE: Corrosion Resistance of Ferritic Stainless Steels
Carpenter has another free machining grade called Project 70 Stainless Type 182-FM, which has 1.5 - 2.5% Mo, and it is ferritic, so it will still be magnetic. I would recommend evaluating this grade, and restrict the Sulfur content to be at the minimum of the specified range.
Now, if you do not require machinability, or do not mind reduced machinability, then you may consider other alloys like Type 434 or Carpenter Chrome CoreĀ® 29 Solenoid Quality Stainless. You can find out more information on Carpenter's excellent website http://www.cartech.com . In order to view all of the technical information, you must register, but it is free.
Compared to a sulfur-impaired 430 ( i.e.430FR), try straight 430. The absense of added sulfur will help. Next go to a titanium-stabilized 430, i.e. 439. In this grade a pinch ( about 0.35%) of titaium ties up all the carbon, nitrogen and sulfur dramatically improving corrosion resistance. It performs nearly as well as 304 and about the same as 434 without the added cost of molybdenum.
Hey, what's the big idea, giving good advice that doesn't include using more expensive material (Mo-containing alloys) or more expensive material (Carpenter's proprietary alloys)?
In all seriousness, I figured I would continue with the Carpenter stuff since artlaf mentioned their specific alloy. Also, the relatively short time it took for corrosion to appear using 430FR made me err on the side of conservatism. I knew you would have some excellent advice on this one.
Mike McGuire
sensitizes the material and it must be annealed to restore its already marginal corrosion resistance. Is this part of your corrosion problem?
Forget Sea-Cure; it's very expensive and available only in flat stock.
