How do I view beams as 3D sections
Hi, I think this is a fairly straightforward question - I have a number of C section and L section bar elements, and I want to be able to see the beams as C section and L section beams rather than just lines. It's just so that I can check the orientation of the elements is correct.
Thanks in advance.
RE: How do I view beams as 3D sections
display > Load BC Element prop then beam display 3D fullspan
Thank you!
