Lead Lag Hinge
Lead Lag Hinge
Lead Lag Hinge
Can anyone tell me what the Lead lag hinge is supposed to do?  I read that somehow it overcomes the coriolis effect but im not sure that I agree with this.  I do know that it must be there for some reason though.  If anyone knows of any good tutorials that show how the controls of a helicopter work(preferably with photos or diagrams)please send me a link.
BM
RE: Lead Lag Hinge
The lag hinge in an articulated rotor system is there to alleviate the high chordwise bending stresses that would otherwise occur due to flapping.
In an articulated rotor system, blades are allowed to flap about a hinge to alleviate the high stresses and hub moments induced in forward flight due to the asymmetry of lift. This flapping motion takes place in a rotating coordinate frame. Just as winds and ocean currents are deflected on the spinning earth, so flapping blades in a spinning rotor experience a Coriolis acceleration at right angles to the motion.
After all, the equations of motion are the same--Newton didn't set up a special case for helicopters...
You can also picture it if you realise that as a blade flaps, it changes its distance from the rotation center by a bit. Like the spinning ice skater who pulls in her arms to speed up, the blade "gets ahead of itself." The situation is reversed when the blade flaps downwards.
The result is that the blade tip wants to describe a small ellipse about a radial drawn from the center. This has a few not-so-obvious implications. For example, because blades can move in-plane, the center of mass does not always coincide with the center of rotation, even for a perfectly balanced set of blades.
Some rotor systems do without a lag hinge. So-called rigid rotors use flexible sections to create "virtual" hinges.
Teetering rotors use undersling to alleviate in-plane stresses. The flapping hinge is displaced upwards from the blade axes. As the rotor flaps, the joint offset causes the descending blade to move *inwards* while the ascending blade moves outwards. These motions generate Coriolis accelerations of their own directed opposite to the forces generated by the flapping itself.
RE: Lead Lag Hinge
The lead lag hinge is to relieve loads on the blade / hub. It is needed due to the blade moving forward and back in the plane of rotation.
The three things that drive the requirement for the hinge are:
1) change in drag as the blade rotates in forward flight
2) movement of the CG in and out and the blade flaps up and down
3) Hook's joint effect caused by tilting the rotor disk with respect to the shaft.
All explained in my book - 'The Art and Science of Flying Helicopters'
Shawn
