Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The level of expertise is awesome. The nature in which people respond is professional helpful and not the least condescending. I can't say that for most forums..."
Geography
janas21 (Automotive)
26 Jul 12 11:58
what kind of magnetic speed sensor we have to use to monitor the speed of an engine flywheel connected to the crankshaft? the sensor will be mounted on the area of the gearbox.
i guess we have to use a crankshaft speed sensor and defenitely not camshaft speed sensors
any ideas?
thanks
IRstuff (Aerospace)
26 Jul 12 12:15
You can use whatever you want, so long as there is a deterministic relationship between what you are measuring and the actual engine speed. A magnetic sensor is only appropriate if there is a some timevariation or change in magnetic field as a function of engine rotation.
TTFN
Comcokid (Electrical)
26 Jul 12 19:57
Google "Geartooth sensor" or "magnetic tachometer sensor". There is a lot of these made for both the OEM and aftermarket, and by gauge companies. For years it has been a common method of adding a tach to a diesel engine.
Close Box
Join Eng-Tips® Today!
Join Us             Close
