Zoom into small component
I am working in a large assembly (component amounts and machine overall dimensional size). The problem I am having is trying to zoom into a small 1mm X 1mm X 5mm component placed inside the machine. I am wondering if there is a way I can select the component I want to find by name or pick from the model tree and then have ProE zoom into the part within the assembly to show me the location?
Thanks...
Thanks...
RE: Zoom into small component
I would venture to guess that your accuracy is set to Relative. Change it to Absolute and see if that helps.
The attached file explains accuracy and how Pro/E calculates it.
Ben Loosli
Ben Loosli
Thanks.
CRTL+F look for part, look by part/ geometry, distance, is less than, x value, type:part, reference click the arrow, and click the part you are looking for in the model tree
Thanks.
Thank you all for your suggestions.
<tg>
Thanks...
