Heat transfer coefficient
Hello all,
I have a questions, can be possible a heat transfer coefficient of 6 (W/m^2/K) between the air inside an office an a pipe of Polyurethane? I assumed natural flow convection. I have calculated the heat flow in a radial direction (everything is known: temperatures, thermal conductivity...) and with a normal parameter of the heat transfer coefficient (15 W/m^2/K)the calculation doesn't have sense.
Thank you in advance.
Cheers
Cheers
RE: Heat transfer coefficient
For a horizontal pipe and natural convection (you might want to consider radiative heat transfer too):
Nu={ 0.60 + (0.387Ra^(1/6))/[1+(0.559/Pr)^(9/16)]^(8/27) }^2
Where:
Nu = Nusselt number
Ra = Rayleigh number
Pr = Prandtl number
All the above numbers calculated using air properties evaluated at film temperature. Please note that the pipe external wall temperature could be (probably is) a bit different from that of the fluid flowing inside.
The problem to calculate an accurate value of it is that the pipe it's not completely horizontal or vertical, also in some points it's touching some platforms...really difficult to be accurate.
Thank you for the info again!
Cheers
TTFN
I don't know if it's clear enough, sorry.
Thanks, cheers.
TTFN
If you have to deal with natural convection and inclined cylinders, you can look on the web for "Raithby and Hollands". They do have developed a correlation for the scenario above mentioned which seems to work quite well.
@ione, thank you very much! I will check right now.
Thank you both.
Cheers.
Nu={ 0.772 + [0.228/(1 + 0.676*(2*L*cot(alpha)/D)^1.23]}*[cos(alpha) + D*sin(alpha)/L]^0.25*Ra^0.25
Valid for L/D>5
Where:
L = length
D = diameter
alpha = angle between the axis of the cylinder and the horizontal
Nu = Nusselt number
TTFN
Thank you
Cheers.
