Assign material to all currently selected members
Is it possible to select a bunch of members in RISA - 3D and mass change their material?
Harris Iqbal
Oceaneering International Inc
www.oceaneering.com
RE: Assign material to all currently selected members
It depends on what version you are running.
If you are running version 9.1 or above, then the Modify Properties dialog allows you to independently change member type, shape, design list, and material. In previous versions these were tied together so that you had to chang them all at once.
