Load factor in pumps
I have a basic understanding of load factor, it being the relationship between design capacity and actual use - and becuase it is related to pipeline diameter, does that mean that it would only apply to the pipeline, and not other parts of the system, such as pump stations?
If anyone knows anything, it would be greatly appreciate - Thanks!
RE: Load factor in pumps
It applies to all pumps, regardless of location. Actually it is related to much more than just diameter of the pipeline, as pump runtime may be included when evaluating part-time operating scenarios, or batching processes on a less than a continuous 24-7 basis. A pump running only 1/2 the time will need 2 X the 24-7 capacity flowrate and a larger pipe diameter, if it is still to meet process capacity requirements. That may affect the number and size of tanks needed and so forth. As such it is one of the most important parameters needed to optimize the design of the entire system.
If it ain't broke, don't fix it. If it's not safe ... make it that way.
Thank you - that was very informative!
