help needs a practical reason why transformers are rated in kva????
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
help needs a practical reason why transformers are rated in kva????help needs a practical reason why transformers are rated in kva????(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: help needs a practical reason why transformers are rated in kva????
Simple but not technically rigorous explanation:
The transformer rating is based on the thermal capability of the windings to dissipate the heat generated by current flowing in the windings. The current is directly proportional to the KVA, not the kW.
A transformer carrying 1 kW at 0.001 power factor will have the same current and heating as one delivering 1000 kW at 1.0 power factor since they are both delivering 1000 KVA.
In designing a transformer, the desired voltage ratio determines the number of winding turns, the KVA determines the windings' conductor sizes based on current ratings.
Transformer rating(kVA)= real power(kW) + reactive power(kVar).
Transformer power rating in kVA, indicates its capable to provide real power such as heat, torque x rpm, force x radial distance in combination with reactive power to provide magnetization to circuits load elements such as reactances and capacitances.
A good characterization unit for the power rating of a transformer is in kVA because represent either 100% real power, 100% reactive power or a combination of kW and kVar.
How would you like to rate them?
