Welding stainless steel onto mild steel
How practical is it to weld a 36" stainlees steel strip 1/4" thick onto a mild steel plate 1/4" thick along the edge?
Are there alternatives to fasten these two metals together?
Thank You
RE: Welding stainless steel onto mild steel
The equipment would be subjected to repeated drops, of approx 150ft, average weight of 200lbs.
All I require is that the weld doesnt break.
Will call local supplier now.
Thank You
BA
www.FerrellEngineering.com
