Elements of a Lifting Plan
I'm putting together some lifting plans for a client for a few steel assemblies we have designed for them.
What elements make up a good lifting plan? So far I have:
location of pick points
weight of assemblies
weight of rigging
allowable angle range for slings
spreader beam and lifting lug details
The actual design of the rigging (slings, hooks, shackles, etc) will be done by someone else.
Thanks for all your help.
weight of rigging
PE, SE
Eastern United States
"If a builder builds a house for someone, and does not construct it properly, and the house which he built falls in and kills its owner, then that builder shall be put to death!"
~Code of Hammurabi
RE: Elements of a Lifting Plan
Also, Who will be responsable for the stability of the lifting rig during the pick? and determining the base reactions at the support locations?
If the rig is on a concrete slab or other, that would need to be looked for the reactions during the lift.
Since you designed the steel assemblies, you should also design, locate and weld the lifting lugs, pad eyes, lifting points, doubler plates, etc. to protect your own fabrication. You know your fabrication better than anyone else, and you don’t want them messing it up with their half baked lifting ideas or welding. A lifting hole or point could be as simple as hole in a flange or web, with doubler pls. if needed. Given the load at that point, selects a min. size shackle for you. But, make all the holes to fit the largest shackle needed, so they don’t need four different shackle sizes. You should know the weight and C.G. of your fabrication and show those on a drawing, in all three orientations. Obviously, you should have a vague idea how the piece might be lifted, or how it should not be lifted.
If they can throw a chain or sling around it and lift away, weld a stop lug on the structure, at a location of your liking, so the chain can’t slip. Maybe note that they should protect the edges from the chain or sling. If you design lifting lugs and locate them where you want them, show a max. vert. lifting load and the shear loading on that lug and let them go at it. They should be able to do the math btwn. your lug specs. and their lifting equipment. You don’t know anything about the rigging so how can you say anything about the rigging weights, lifting sling angles or spreader beam details. Those are the riggers responsibilities, and dependant on his equipment, the crane size, etc. If your structure will only take a vert. load at a given lifting lug, your sketch would show a vert. max. cap’y. and zero lateral/shear loading. To that extent you can direct the rigger in how he treats your fabrication. This info. can be shown on a cleaned-up arrangement drawing of the piece in question, along with some basic lifting and rigging directions.... comply with OSHA, ASME Below the Hook specs., etc. You should assume the responsibility of protecting your own fabrication, but don’t assume the rigger’s responsibility by telling him what to do.
I had the lifting lugs on the assemblies themselves taken care of. However, I didn't realize OSHA requires the capacity of the spreader beam to be stamped directly on its side. That's a good detail to make sure I include!
PE, SE
~Code of Hammurabi
Normally lift plans are lift specific and do not include things required by code and required for any lift. For instance, the lift plan would not normally say any thing about the fact that the rated capacity of a lift beam must be clearly marked on the beam. That is just one of many requirements for a lift beam that is required by code. Rather, inspection records and certifications are submitted demonstrating compliance with all code requirements.
Need to add site develoment requirements to the list. This includes marking out underground hazards and supplemnting the crane pad with crush stone or cribbing.
Also add responsibility list identifying key characters.
PE, SE
~Code of Hammurabi
1. Are they required to use a spreader bar? Saying "yes" makes your math easier with no compression in the assemblies.
2. If they aren't (most contractors don't want to rent or fabricate a spreader bar) tell them what angle sling you want. ASME B30.9 (Slings) gives convenient charts for slings at 60, 45 and 30, so I'd design for one of those.
3. Specify the size pin you need to go through your lifting lug for bearing or tearout. This will translate to the size shackle they need, so check a Crosby catalog to make sure the pin size you pick goes with a shackle that has the minimum working load limit (WLL).
4. Service reactions at the lifting lugs so they know how to size their rigging and crane.
Design your lifting lugs using ASME BTH-1 (Design of Below-the-Hook Lifting Devices). It gives specific factors of safety for lugs and connections, plus a good guide for lugs.
