ACI Wall Design
ACI Wall Design
In designing a concrete wall for compression using ACI is it acceptable to use the column equations of chapter 10 with a steel area of zero? Does the chapter 10 equation give you higher concrete strength due to confinement of the ties, and thus would not be applicable for a wall (assuming wall has no ties). The only other option that I see is the empirical equation which seems conservative.
RE: ACI Wall Design
RE: ACI Wall Design
ACI 14.3.6 ('05 edition): Vertical reinforcement need not be enclosed by lateral ties if vertical reinforcement area is not greater than 0.01 times gross concrete area, or where vertical reinforcement is not required as compression reinforcement.
So ignoring the steel area in computing compression strength would be an acceptable approach.
