Hot tube immersed in cold water
Hello everyone,
I am a new user for solid works. I am very grateful if someone could give me some advise how to work on Solidworks simulation for the situation as follow:
For a tube (steel) with an initial temperature of 390K is immersed in a cold water bath where the water temperature is 285K. Here, could anyone suggest it how can i simulate the heat transfer after a certain of period? Do i need to model the water as a block and if I do, how can I insert the tube into the block of water so that I can observe the heat transfer between these component?
Any suggestion is much appreciated.
Thanks.
Syarifadam
