Hole Call out
Hole Call out
Does anyone know how to change the default hole call out? Please see the attached word document to see what I'm talking about. Mainly we want to change it from placing the number of places being put at the begining to being put on the end and it saying _ PLACES not (12)x. Also, we want it to just say THRU and not THRU ALL. Thanks in advance for your help.
RE: Hole Call out
HTH,
Dan
Han primo incensus
RE: Hole Call out
It may be one of "calloutformat.txt" or "calloutformat_2.txt" in the same folder.
Han primo incensus
RE: Hole Call out
Jeff Mirisola
Director of Engineering
M9 Defense
My Blog
RE: Hole Call out
You can create a custom file for the callouts and locate it wherever you want, even on a server so everyone can share. Make a copy of the original file and edit it the way you would modify code by commenting out the original line and putting in the new descriptive callouts. Then under tools/options/file locations/hole callout format file/ point to the new file. To revert to the standard SW file, jut redirect that setting.
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
RE: Hole Call out
