UniGraphics NX 7.5 Inferred dimension failure
Hi All,
Anyone have any ideas on the error messages when trying to complete an inferred dimension ?
FAIL TO OPEN DATA FILES
Not seen this one before, any ideas welcome.
Many Thanks in advance,
Mark
RE: UniGraphics NX 7.5 Inferred dimension failure
I suspect that your best bet is to take this up with GTAC.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi John,
Thanks for you help, I found this on the GTAC site and needed to add these files to the correct folder after the 7.5.5.4 update.
PRODUCT: NX
SUBJECT: Cannot Find Data Files when Creating a Dimension
SYMPTOM/PROBLEM
When adding a drafting dimension, the error "Failed to open data file" is
returned.
SOLUTION/WORKAROUND
When pointing to a custom folder for the variable UGII_DRAFTING_STANDARD_DIR
you must assure all the UGII_BASE_DIR\drafting_standards files are copied over
(ansi, din, eskd, gb, iso, and jis). Once all the files are copied over you
should be able to create your drafting annotation.
Note: You should not have to restart NX, because NX looks for the contents of
these folders every time a dimension, or a PMI dimension is created.
