Moving objects to a layer in an assembly?
I have a simple task, that is to move all visible items to layer "3" at the parent assembly level (that contains both features at the parent level and components/subassemblies).
This is what I do:
-draw a rectangle around everything I see to select all objects, then "Edit object display", type in "3" for the layer.
To check that the operation was successful, I go to Layer Settings, toggle off layer "3", and everything disappears. So it seems that the operation was successful. To further confirm, I select any feature/solid at the same level as the parent assembly, go to "Edit object display", the layer box says "3", which is correct. However, if I select a component or subassembly, go to "Edit object display", the layer box says "0". So something here is wrong. To further check, if I export the parent assembly to a STEP file, choose to export only layer "3" in the settings, only the parent level solids are exported, non of the components/subassemblies.
How can I "force-move" all objects, including components/subassemblies to layer "3"?
This is what I do:
NX8 i7-3770K@4.3Ghz 16GB Quadro2000
RE: Moving objects to a layer in an assembly?
- select any component of desired sub-assembly
- pres Edit->Selection->Up One Level.
Then automaticaly selects all your sub-assembly. So then press Format->Move To Layer and select layer you want. Only in that way you will be sure that all components of your assembly/sub-assembly will be moved to desired layer.
In your case "Edit object displays" is showing "0" layer, then at least one of the components/objects in your sub-assembly is in different layer.
Format -> Move to Layer...
...to move objects to another Layer?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Tim Flater
NX Designer
NX 7.5.4.4 MP2
WinXP Pro x64 SP2
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
Tim, what are you saying?
I believe the problem is that I need to define the layer of the component at it's own level. I think what's happening when selecting all sub-assemblies at the parent level and moving them to layer "3" is that it only affects the sub-assemblies at the parent level. What I need to do is go into each and every part by making them the Displayed Part and moving the solids to layer "3" there instead. I've tried this, and when exporting to a STEP file, finally the layer 3 objects get exported as they should.
So, a solution to my problem is to make each part Displayed Part and move the objects to layer "3", but when there are maybe 100's of parts in the assembly, that is going to take at least an hour of incredibly tedious work. Isn't there an easier way to move all sub-assemblies and everything below to another layer in one go, where the layer change is made at the part level?
Isn't that a bit harsh
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
If this is something you will be doing on a regular basis, perhaps creating a journal would be in order...
www.nxjournaling.com
To make it clear, this is an example:
PART A
->PART A1
->PART A2
->PART A3
PART A is an assembly containing 3 other parts, each which contain solids. The goal is to move all the solids in each part to layer "3". Moving PART A to layer "3" does not do this. You would have to make PART A1 the displayed part, then select all the solids and move them to layer "3". Then repeat for PART A2 and PART A3. This is very tedious if you have many parts. How can all this be achieved in a single operation?
If I change the layer through the properties then perform an "info object" on the component, it will report "layer 3". Repeat the info object (filter for solid bodies) and it will report "layer 3, inherited from component". So, from what I'm seeing, it does move the component and solids (in the reference set) to the target layer. Does your assembly report something else?
So, for example, in this scenario:
PART A
->PART A1
->PART A2
->PART A3
While in PART A, selecting the solid of PART A1, performing info>object, the result is "Layer 3, inherited from component". HOWEVER, if you make PART A1 the displayed part, then perform the same info operation on the same solid, the result is "Layer 1". This is where the problem is, it should be "Layer 3" instead.
This only works if you choose "export selected objects" in the step export dialog box. However, if you export "entire part" (to retain the assembly structure and part names in the step file) , the exporter checks the layers on each individual part file, not the assembly layers. Therefore I still need to find a quick way to change the layers on all the individual parts.
-export from displayed part
-export entire part
-export solids
-layer selected: 3
When you export with these settings are you able to properly export the assembly when the solid in the individual part is on layer 1?
When moving components, you must select and go up one level to capture everything to be moved.
Tim, that may be an issue but it could also be a lack of training. Too many companies treat training as an expense rather than an invetsment in their employees. If the employee is trained properly, they can save the company man-hours per month by being more productive by their increased knowledge of how the software works.
Ben Loosli
If the person receiving the STEP file wants everything on Layer 3, let them worry about organizing the file this ONE time and as you create your assemblies in the future, you can take the very sound and logical advise from cowski, Ben, et. al. and take this ultra important layer convention into consideration as you're building your assemblies.
Tim Flater
NX Designer
NX 7.5.4.4 MP2
WinXP Pro x64 SP2
You start leaning too far one way and the boat WILL tip over and you'll end up with potentially hundreds if not thousands of assemblies that are completely hosed for one reason or another. This inability to do these seemingly menial tasks across the entire assembly is in place to help the user spend less time worring about which sub-assemblies and/or components are going to be affected by what seems like an insignificant change.
Could Siemens take a look at this one little thing (moving components between layers ONLY) and possibly change it - yes, they probably could. Will they? Very doubtful because in over 15 years of using NX, this is the FIRST time I can recall someone wishing to do this particular task, at this point in the design cycle. Does that make it less important or any less of a good idea, no - but the NX folks tend to put their resources into the larger holes first.
Tim Flater
NX Designer
NX 7.5.4.4 MP2
WinXP Pro x64 SP2
Deleting the unwanted features is not a feasible method. Let me explain the situation in more detail. The STEP exporter ("export entire part") will export EVERYTHING in the assembly except suppressed components. Hidden objects will also get exported. I want to export ONLY the visible objects. So following your suggestion, I would have to find all hidden objects and delete them. I would have to search through the entire assembly, part by part, looking for hidden objects and deleting them. And often, there will be some obscure, unwanted object that does slip through into the STEP file, so I would then have to go back to the NX assembly to find that object and delete it. This tedious and time-consuming process is what I'm trying to avoid.
So I'm thinking, why not simply at the parent level, select all visible objects, move them to a layer (layer "3", for example) and export only that layer. But, as you eloquently explained in your last post, it's not possible to move components between layers throughout an entire assembly.
The suggestion to start every part in layer "3" wont' solve the problem, because there can be many objects within the same part that I don't want to export.
I'm sorry for this "debacle" and long thread, and greatly appreciate everyone who has tried to help.
CATIA V5 R20
PC-DMIS 2011 MR1
It would have been very nice to have all the facts at the beginning rather than bits and pieces at a time...our responses tend to rely on accurate information that isn't going to change after several responses.
Tim Flater
NX Designer
NX 7.5.4.4 MP2
WinXP Pro x64 SP2
I hide the objects as I go along. When for example creating a cut using a solid as a tool, I will hide the solid when finished with the cut. And some linked objects are used as reference, so I hide them too when I'm finished with them. This I do by right clicking and selecting "Hide". So along the way when creating an assembly of parts there will be lots of these solids that are hidden. These I don't want to export to step, but the problem is, they WILL get exported anyway, the way the translator works in NX. Realizing this quirk with the translator, I then came up with the idea of moving only the visible objects to layer "3", then only exporting that layer. That was what the opening post was about. But based on the replies, that is not a feasible solution, so I'm still stuck.
Tim Flater
NX Designer
NX 7.5.4.4 MP2
WinXP Pro x64 SP2
cowski, they are in various component files.
