using associative ID symbols in notes
Is there anyway to add the ID call outs of items in the BOM, associatively, to notes in that are in the drawing? what I want to do is have notes like ITEM 3 IS TO BE PLACED.... and have the number 3 associated to the part with that ID. That way if the parts list changes the notes are updated same as the ID symbols. The parts list item number is $~C but that won't bring in the item number and if you don't use that circle for the ID symbol, it won't be associative to the ID.
RE: using associative ID symbols in notes
I'm writing in reference to NX 7.5, for versions down to NX 5 or so the sequence should be similar.
www.nxjournaling.com
