Screw Specification
Screw Specification
hello everyone
i just have a simple question regarding the callout of a screw.
can someone explain what the 't' in a T3.0x10 screw means? is this torx, tapping or something else?
this is going to kill me if i dont find out!
thanks
gm
thanks
gm
RE: Screw Specification
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
http://www.eaglefastener.net/technical/screw-point...
Also, in your designation the 10 is where the thread pitch should be, but the value of 10 seems unlikely assuming that 3.0 is mm. All of course assuming that this is metric.
I think the 10 is the lenght of the thread, just as M3x10 in metric thread
the dia is 3mm and the lenght of the thread is 10mm;
Is that so difficult?
Greetings
So without reference to a relevant thread standard the situation is ambiguous and so yes, if this is a real life question from the OP rather than 'I saw this in an article and didn't understand it' then Jboggs is correct and the OP needs to ask whoever gave him the spec.
Thought standard pitch was outside Europe also never mentioned.
