Hidden code in Omron CPM1A
I've got a problem with Omron Sysmac CPM1A-40CDR-D.
My machine controlled by cpm1a doesn't make all programmed moves like before. I suppose PLC is a cause. I thought that some instructions in code hangs or malfunction, so I have connected PLC to PC, imported instruction set code into Syswin 3.4 and analized. Seems like some code doesn't display. Those what is displayed is not complet. I was told that a software producer hides some code, provides himself monopoly for repair service :) So my question is:
How can I view hidden code?
Thank you in advance for any help.
RE: Hidden code in Omron CPM1A
I would think (hope) that it cannot be done without assistance from the original author.
In syswin 3.4 there is no option like hide, secure or password protect. Which program should I try then?
