Sub Areas and Pond Surface Area
Peter
I am modeling several sub areas and ponds. Does the pond surface area need to be added to the sub area size? Or, does hydrocad recognize the pond surface area when a pond node is added to the model? If hydrocad recognizes the pond surface area when a pond node is added, what curve number is being used in the runoff calculations?
Example:
Sub Area Size = 5 acres
Pond Surface Area = 1 acres
Do I add my sub area size at 6 acres with a weighted curve number, or do I add a sub area node @ 5 acres with appropriate curve number and a pond node with stage storage table?
Thanks in advance
Scott
Example:
Thanks in advance
Scott
RE: Sub Areas and Pond Surface Area
For details see http://www.hydrocad.net/pond.htm
Peter Smart
HydroCAD Software
www.hydrocad.net
Scott
