Two-core and earth , flat cable
Hi hope you can help.
I can not find in the AS/NZS 3000 wiring rules, if Two-core and earth flat cable is required to be mechanically protected.
The contractors have used this cable between the 415V AC board and 240VAC socket outlets & Sump.
I would of thought that this cable would require some form of mechanical protection.
Your Thoughts
Thanks Craig
Your Thoughts
Thanks Craig
RE: Two-core and earth , flat cable
Depending on the site (i.e. mine etc), the governing body may have blanket rules (generally all cables must be protected).
Lyle
