CAD file opened in Visio...
thread555-188053: AutoCAD to Visio to Word
I tried to look up a similar thread but no luck and not sure if anyone has had this problem or not.
At my office we (myself and the only other engineer) use Microsoft Visio to do any drawings or schematics, mainly because he has been here for 8 + years and that is what he knows how to use and likes. He sent off some drawings to get reviewed and stamped by another engineering company and they sent back the drawings made and edited in AutoCad. First problem was we could not open the files. They all said corrupt or extension was incorrect so I had that guy save them as CAD 2000 dwgs and dxf files and they opened just fine.
Next problem was my coworker needed to edit the drawings some more before he submitted them again. When I right click the drawings and then Convert on 2 or 3 of the 5 drawings some items just disappear. Why? Before converting the drawing they are all grouped together so we cannot edit it but after I click convert so Visio can see separate components the screen loads then the drawing flashes to a white slate really quickly and then (on the specific drawing we are trying to change) the top half goes away.
I have attached the original drawing and the result after converting hopefully someone can tell me a fix? I have AutoCad on my computer at home so I was going to try to load the drawings on there and see if they can be saved not as a group or converted on there first possibly but if anyone knows a fix from the Visio side it would be helpful to know!
Before
After
Before
After
RE: CAD file opened in Visio...
Conversion back and forth between formats always loses something. Worse, you may not notice right away.
If AutoCAD is too pricey for you right now, take a look at Dassault Draftsight.
Mike Halloran
Pembroke Pines, FL, USA
Side note - I tried a number of different things on the CAD side to make it work in converting in Visio but the other group had made part of the drawing using a MetaCAD file so that is where the problem was. I finally decided enough time was wasted trying to fix it and decided to just use Visio tools and trace the objects that were going away.
