Maintain surface color when using translate command
When I use the Translate command to translate surfaces, using the axis to axis option, the color of the surfaces all change to one color, that being the default light yellow color. For example, 3 surfaces each having a different color (red, green, blue) and after translation, they all change to the default light yellow. Is there a setting somewhere or a way to where the surfaces will remain the original red, green and blue and not turn light yellow after they land at their new location?
Thank you in advance for any help on this issue that anyone can provide.
v5newto
v5newto
RE: Maintain surface color when using translate command
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
