metal stud wall diagonal bracing requirements
2009 IBC
1700 sf salad restaurant
type IIB, no sprinklers
1 story shopping center shell upfit.
new interior metal stud walls; the partition types called for bracing diagonally every 4' OC (prototypes).
in richmond virgina they use slip track metal heads to attach walls to roof deck above....if the wall is extended all the way to the roof deck & attached with the slip track detail is the diagonal bracing still required by code?
steve yarnall
http://svyarchitect.blogspot.com/
RE: metal stud wall diagonal bracing requirements
steve yarnall
