Excel 2003
Excel 2003
Excel 2003
Primary Secondary
F V
P T
F T
L V
H Y
F V
T T
X V
F I
F T
T T
P V
H V
Z SC
H V
F V
L V
H Y
F I
Above excel data on "sheet1". On sheet 2 tryin to count say e.g. number of "FV"s. Any suggestion for formula.
Thanks.
RE: Excel 2003
If you use VBA, you can just do a count for y=1 to 50 IF cells(1,y)=F AND cells(2,y)=V then x=x+1, display x
RE: Excel 2003
if cell values are text in separate columns, then try placing this formula is adjacent column
=if(and(a1="F",b1="V"),1,0)
if cell values are in same column, the try
=if(a1="F V",1,0)
you can then sum or count the "ones". crude method, but works.
good luck.
-pmover
RE: Excel 2003
Bollywood - this question should have went in the Engineering Spreadsheets forum. Red Flag your post and ask management to move it. You may get some other advice/options over there.
Good luck,
Latexman
