"Folder cannot be displayed" in Windchill 9.1
I'm currently using Pro/E wildfire 4.0 and windchill 9.1. There was some problem with server and windchill went to offline (no server) mode. When I started Pro/E again I changed server from tools->server manager back to normal. Now I can see my current jobs in Workspace but I haven’t access to Windchill Cabinets. When I try to go to Windchill Cabinets text Folder cannot be displayed. The contents of this folder are not available appears. Pro/E doesn’t ask any user name and password anymore so I assume that I should log on somewhere. So, how can I get access to Windchill Cabinets again?
RE: "Folder cannot be displayed" in Windchill 9.1
In server manager choose the server and right clik and choose set as primary server.
Check your config.pro for web_browser_homepage setting, it should be to your PDMLink homepage.
Also Tools-Server, needs to have a workspace registered. If it is No Server, then configure your server and set a workspace.
For the server name, everyone should be using the same name, PDM, PDMLink or some company specific name. There are sometimes folders referenced that are in PDMLink and use that server name. In config.pro. look for wtpub:: for any directory references, those are the ones in PDMLink.
Ben Loosli
