WF-WF lateral connection
2 W18s, 2'-4" apart. I need to connect the two together to transfer shear from one to the other but the connection needs to allow for vertical movement.
I was thinking of using 2 bent plates, one welded to each WF. Then I would connect the legs of bent plates with A325-N bolts with one leg having a vertical slot allowing for movement. And this is where I have a concern as I am not sure that simply putting a vertical slot will allow for vertical movement. I am confused.
RE: WF-WF lateral connection
This is a little confusion. Allowing vertical movement and resisting a vertical shear load sounds like a contradiction.
www.FerrellEngineering.com
Two parallel beams 2'-4" apart can be interconnected for vertical shear transfer only by putting a torsional moment in each beam. A slotted hole is out of the question.
The whole idea of transferring vertical shear in this situation seems wrong. Or are you talking about horizontal shear?
Perhaps a sketch would clarify what you are trying to accomplish.
BA
Are you actually trying to describe resisting horizontal shear and allowing vertical movement?
JAE, yes. Transferring lateral/horizontal force and allowing vertical movement. Sorry for the confusion.
Use a horizontal brace between the members, hinged at each end. No slotted holes required.
BA
