Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...My thanks to the contributors who freely share their knowledge and enthusiasms. This forum restores some measure of my faith in human nature..."
Geography
Troubleshooting accelerometer/DAQ "Over-range" errors in vibe measurementHelpful Member!
NihaoLamancha (Mechanical)
22 Jul 12 18:54
Problem Statement: Need help to isolate "over-range" errors which occur intermittently during vibe measurement
*Objective: Characterize HALT chamber vibration range - Measure acceleration PSD on vibration table of HALT chamber and compare to setpoint
*Instrumentation:
-Accelerometers: 5 single axis, PCB Piezo, +/- 500g range, 10mV/g sensitivity, all attached to table (next to each other) with bees wax
-DAQ: 8-channel Wavebook 512 by IOTech; eZ-Analyst software (both > 12yrs old)
-Configuration: Freq range 10-5000Hz, selected correct accel input range, sensitivity
*Observation:
-At 5Grms - all 5 accels read within 0.3Grms of each other and setpoint
-At 10Grms - all 5 accels read within 0.9Grms of each other and setpoint
-At 15Grms - start observing "over-range" errors on few channels
-At 20Grms - all accels have "over-range" error
-Swapped some accels; error reproduced intermittently/at higher vibe level; Also occurred on 3-axis accel
-Changed accel location to different area of table. Again mixed results - Some channels over-range and sometimes dont.
Would like ideas on how to isolate issue to instrumentation or software. Note: IOtech was bought by National Instruments but do not have any development/support on Wavebook.
GregLocock (Automotive)
22 Jul 12 20:22
I'd try fixing your signal leadss to the table with more care.
Cheers
Greg Locock
22 Jul 12 20:30
Incidentally I'd be a bit leary of beeswax for a test rig, especially when you aren't happy with the signals. yes, i know it has the frequency response.
Cheers
Greg Locock
IRstuff (Aerospace)
23 Jul 12 1:52
Did this setup EVER work? You're supposedly using a ±500g accel with ostensibly ±5V output feeding an ADC set to what gain?
TTFN
Helpful Member!  amanuensis (Automotive)
26 Jul 12 10:42
In my opinion, it's not a good news. This certainly indicates that your accelerometers are soon out of order. Actually, the lifetime of a PCB piezo is around 6 years (from my own estimation ;) and eachtime, I got the same type of fault before accelerometer fails: over-range when level is higher than around 10g...
Strong (Mechanical)
26 Jul 12 15:36
I have both a WaveBook and ZonicBook. The 8-channel Wavebook does not have anti-alias filters, so this may contribute to overload issue with out of frequency range high values. I had to add a separate 8-channel module with ICP and anti-alias filters.
Walt
Close Box
Join Eng-Tips® Today!
Join Us             Close
