ANSYS LS-DYNA export,
Good morning,
I have the next situation: to resolve the impact of sloshing water in a tank in a moment of seism. To do this study I will used ANSYS LS-DYNA (from ANSYS 14). I observed that, if I will used as preprocessor ANSYS LS-DYNA from ANSYS WORKBENCH interface, they export only .k file. How I can export the FEM model in ANSYS LS-DYNA from ANSYS Classic interface?
Thanks in advance for yours advice.
Best regards.
Best regards.
Mess with the best die like the rest...ANSYS is the best !!!
RE: ANSYS LS-DYNA export,
(Solution/Write Jobname.k/ put
write results:ansys and lsdyna
write input: namefile) and generate file *.k
Only you can do in ansys lsdyna not in ansys clasic because is a trasient analysis.
