New Footing Next to Retaining/Foundation Wall
Hello:
I am designing at footing next (on the unexcavated side) to a retaining masonry foundation wall. New footing will support a three story steel porch structure. Question is,
The reinforced pedestal is 36"x24" rectangular in plan and 7'-0" high and it will be beneath the earth right next to the existing foundation wall. do you consider such high pedestal a column?, what do you use for "K". Once construction is finished it will be completely surrounded by compacted earth. Your comments are appreciated.
RE: New Footing Next to Retaining/Foundation Wall
A more proper establishment of one equivalent K for stability issues will be difficult, particularly because of the indeterminacy of the buried condition ... earth may be causing spreading forces against the pedestal that won't be being counteracted because of the jointing material -buckling of one in-length laterally loaded member- what normally will remain an unknown. It would be wise make some allowance for such actions.
