Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks! Awesome group. I put out a simple question in the access/vba forum that I couldn't find answered on technet or anywhere else on the web and it was answered the same day!!..."
Geography
DHKpeWI (Structural)
20 Jul 12 17:57
This is for users of the CFS program by RGS Software for cold formed steel member design.
In the member check menu, the user is required to input the axial loads, moments and shears. Must the maximum shear and moment be used even if they do not occur at the same location?
Thanks.
ishvaaag (Structural)
20 Jul 12 19:04
That would be very anomalous since all the effort in structural design is driven towards examining all the prescriptive combinations that may control the design, but only these. Hence my view is that except the code mandating otherwise, only concomitant solicitations at the sections / members should be examined anytime.
PMR06 (Structural)
21 Jul 12 21:04
The member has to work at all sections, for the forces it sees at that point. Hence, unless you are creating the shear, moment and axial diagrams as inputs, you should only input forces that happen at the same point.
To be completely thorough, you could check the point of max moment, with the axial and shear that occur there.
Then check the point of max shear, with the axial and moment that occur there.
Then the point of max axial, with the moment and shear that occur there.
Close Box
Join Eng-Tips® Today!
Join Us             Close
