holes locked down
holes locked down
holes locked down
Is there a setting that locks down holes when placed. After I place down a hole, I try to dimension it to move it and the hole does not move and the dimension appears with an underline under it. I use to be able to move holes but seems like something has changed.
RE: holes locked down
you have to click the maintain relationships button. the underline means it is not in scale
