Part Families
Part Families
I am creating an assembly part family of some components. I have 2 components that are a part of my family that are a left and right side. The part numbers of the components are in the format of 123456-L and 123456-R for the left and right side. When I create the part family and look to add the components I am only seeing a line for a component of 123456. This will only create one column in the part family table for both parts even though they are different. Is there a way I can get the available columns in the part families to show both parts? I cannot change the part numbers of the components since they are company standard part numbers.
Randy
Randy
RE: Part Families
RE: Part Families
RE: Part Families
Now if you create the family table and choose component you will see part1 and part2, otherwise if you don't change the names, there will only be 123456 and you have one column.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
