back pressure regulator
Hallo!
Can somebody write equations which present the function of a back pressure regulator?
thankyou
jg
RE: back pressure regulator
Maybe. Can you provide more information?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Try here:
http://www.equilibar.com/back-pressure-regulator/b...
The above should explain the functionality.
Flow and pressure drop through the regulator can be calculated by the formulas easily found in vendor literature or various engineering articles, etc.
Good luck.
