Electic Routing Insulation/Cover
I changed the appearance, but it is still transparent. Any troubleshooting tips?
RE: Electic Routing Insulation/Cover
Check whether the material have you chosen is transparent.
Expand the Display Pane (double chevron at top RH corner of FM) and check transparency setting there.
Also right click in the Display Pane and select the Remove all part appearances option.
